53strands
- Sep 29, 2021
I was looking at some designs for controller/power supply housing, and I came across two different power wiring types. 1: The power going to the pigtails is run right of the controller. 2: After going through a fuse block, the power runs right into the pigtail, and leaves an open terminal on the screw terminal on the controller. The picture below has both. What is the difference between the two? Does it effect the brightness or distance the power can travel? Thanks!
