Controlling LOR CCR with P12r
dannyp
Sydney
I have a bunch of LOR Cosmic Colour Ribbons which I wonder if I can control via a P12R. Can someone advise if the P12R is able to control these strips?
Many thanks
The CCR's actually have 6803 chips in them, so if you set your P12R to 6803, you should be all good.
FastEddy has done this, so if you have any issues, he'll be able to help out!
Correct, I use My CCRs with the P12R and then use my CCR controllers to run 6803 modules, they all work great. So just treat the CCR as a 6803 strip and you should be good to go. Just make sure you get the +V and the Grnd correct when you connect up or else you will damage it.
fasteddy, how do you use the CCR controller to control the modules? Do you just load a sequence into the CCR controller and run it in freestanding mode?
