Superstar files can be directly imported into xlights. Importing an lms file is the wrong way to go. You will get a ton of node level effects. If you must use lms then add as a data layer.parts223 said:I do not want to use both LOR and Xlights.
The idea is to import the Pixel Editor file into XLights and then be done with LOR. I really don't want to recreate all of my Pixel Editor sequences in XLights. I would love to be able to import them.
Superstar files are no problem because they can be exported to .LMS which can then be imported into Xlights.
The Pixel Editor .LPE files are a different animal entirely.
