Creating a Scheduled playlist
Madko
Castle Hill NSW
Im needing some help with setting my play list to start up.
Under Output menu i went to create/modify show schedule. I filled in sunday to saturday (first line only) with start time and finishing time for my HLS sequence. Saved that.
Now this is where im lost. How do i start that show schedule? Do i need to open a blank HLS program, go to play specific play list, select my file and select play per schedule and leave that dialogue box open? Do i need to tick any for the boxs, test show or write debug file for output??
Any advice would help.
Thanks for that. Howver as im running off a portable harddrive when i open up HLS and go to the output menu and select play show schedule it tells me that HLS is unable to open show schedule.
When i open HLS and want to open my sequence i go to File, open but then to open my file i have to cancel the pop up and open the file directly through the directory.
Anyway of make the scheduler open?
Hey All,
Fixed! thanks for the HLS Sequencer link. I found that my issue was i was setting up a schedule within my program and then trying to run that from a blank HLS screen. The schedule needed to be all setup with a blank HLS and no data loaded. This was my issue.
Just in case anyone else has this issue/concern
