Lampy
- Dec 4, 2012
Hi all, first post here. Trying to build some rgb lighting fixtures for use at gigs. Looking for any help and advice about
products to use including rgb led strip, dmx decoder/controller and the power supply!
Basically it is an upright standing frosted perspex tube that will have rgb led strip glued at the back on the inside. I have
attached a drawing to give a representation, these need to be super bright as they may be used in daylight occasionally, there will be 3 strips together at the back to add to the brightness. As the tubes are 1.7m tall then the 3 strip adds to 5m which is a standard roll length i believe. The only real complication to this project is that i will be controlling it via dmx and want to be able to do things like a chase up and down rather than the whole strip on together at once. Also i would want to be able to have the 3 strips mimicking each other i.e a chase going up and down across all three strips together. I guess i could give each strip a seperate decoder with the same dmx address, or is there a better solution?
So really, if anyone has suggestions for rgb strip (minimum 14w/m), power supply and dmx decoder you would be helping me hugely as this is all over my head. Thanks
