bdt
Can someone explain the difference between a DMX bridge, DMX controller and pixel controller?
If I understand correctly, the difference between the DMX and pixel controller is that the pixel controller can be configured for specific lights whereas if you use a DMX controller the object you are controlling must be DMX compatible… if this is correct I basically understand the DMX and pixel controllers. However, what is the difference between the bridge and controller. Are they similar in difference between an Ethernet network hub/bridge, switch?
