Does anyone know roughly how long RayWu's Dumb RGB LED string "IP68 DC5V input 12mm through hole LED
Re: Does anyone know roughly how long RayWu's Dumb RGB LED string "IP68 DC5V input 12mm through hole
In standard configuration they are around 4" (100mm) between leds, however 3.5" is more realistic as the spacing is sometimes a little less depending how much they lost when sealing the ends.
based on this a 50 node string is typically 14.5 ft (4.4M)
You can always specify the spacing if you wish as a custom order and the cost doesn't change much, so you could go 50mm or even 150mm.
in china, the pixel string's line all 10cm from one led to another, if you longer you must order.
