ptone
So I've recently received a couple test units of stageape.com RGB LED  par lights.
These are pretty low end gear, but the price is right.
I'm controlling them through OLA and an EthCon DR4
Now in the software (custom Python software) I was initially using a refresh rate of 40fps, as that is my understanding of the fastest a full 512 universe can refresh at. However when I dim these LED par lights at that rate, the step change is VERY obvious. Near as I understand it, this is in part a function of the cheaper controller in the light in that it is not doing any effective PWM dimming between steps.
So, with my single test light, I tried increasing the framerate - and tried as high as 400fps.
At somewhere close to 200 fps, the dim became smooth as silk. But lets use a framerate 4x of what I started with, 160 - it was still good. Now with my basic understanding, that would roughly limit me to 128 channels of DMX per universe at that rate. With the EthCon DR4 and 4 universes, this still gives me a full 512 channels.
My question is about overdriving. What are the refresh limits of the EthCon? Seems like there would be one limit that is about bandwidth (only so many bits per second), the other is some limit of refresh rate (regardless of frame size).
How would one know if you are overdriving the rate of the EthCon? Would it just drop packets, buffer them - I'm guessing that is what those other columns in the slave stats are about?
Also - now that I might use all of the universes, I might be running some longer stretches of cat5 - are there any line length limits on the Cat5 runs from the EthCon? I'm then converting to 3-pin XLR before going direct into some DMX fixtures (no a controller dimmer).
Any wisdom here appreciated.
-Preston
-Preston
