E1.31 works Xlights Does'nt
SmartAlecLights
Murray Bridge, S.A.
Ive have used 2 komby transmitters over the last couple of years (vixen)
an i can test them to make sure they work via da_e1.31 program.
but xlights just wont turn them on... (even in test mode)
(weird bit i cant corrupt (strobe) the data by running xlights an e1.31 at the same time)
i would like to get at least one of the transmitters working as it controls 3 receivers all doing inside windows
Last time I had issues like that, it was because even though I set the output to only X channels to the controller, the software was still outputting all 512 channels to it.
Gilrock said:
Well in your screenshot you don't have the Output to Lights button active.
i enabled it for testing a pattern..
i also went to the test screen.. but still nothing..
Re: E1.31 works Xlights Does'nt - Solved
Solved.. apparently the komby was looking for all 512 channels an only saw 510 from xlights ..
