ECG-P12S/P12D combo with dead outputs
moondew
Iowa
Has anyone run into an issue with an ECG-P12S/P12D combo board set where there is no data on the second six outputs?
I reflashed the board from 3.4 to 3.4b and now all the outputs are dead. :-(
-Tom
I reflashed the P12S board with firmware 3.4b and then all outputs were dead. I reflashed again just incase I made a mistake but still all dead.
Strangely, the ASIC version numbers on the System Information web page were all zeros.
So I flashed 3.4 instead and now all outputs work. I am guessing that ten years ago when I originally flashed 3.4 I must not have programmed the second ASIC. Unfortunately, 3.4 does not support two full universes per output with 2811 pixels.
However, I would really like to get 3.4b working. I sent Ed an email but I will be surprised if he replies.
Unfortunately, you only have LP035 firmware and my board needs LP047
I just checked and still have some J1SYS files. Are these what you need?
ECG_P12S_v3_4.hex
ASIC_P12S_v3_4B_LP047.ahex
