Elementary Problem -- Can't see woods for trees
garyjac1
Dalby
OK,
Regarding the PR12 from JSys. It has 12 universes (12 sets of terminals).
How do you describe each universe to LightShow Pro -- is each universe seen as a separate controller?
Regards,
Gary
Appears to be a very similar question that you asked in a different thread, so ill give the same answer
http://auschristmaslighting.com/forums/index.php/topic,2404.0.html will show you the best method, create elements not controllers as this is how you get the most control and power from LSP. An element is just basically a controller that you create with just the number of channels that the element uses. This allows for easier management of all your display elements when sequencing and grouping into layers for use with transitions and macros.
