perigalacticon
I am running ESPixelstick 4.0 for the first time and I'm using an Adafruit Feather ESP32 module. I have found that the data on channels 3 and higher get corrupted with random patterns when I increase the brightness beyond about 25% when controlling directly from xLights. I am unable to use channel 1 because that is GPIO 2 which is not broken out on the Feather board. Channel 2 works correctly, tested up to 50 pixels. Higher channels do not work if the brightness is increased on any of them beyond about 25%. Has anyone ever had this problem and knows how to fix it?
Thanks.
PS the strands work fine on other controllers.
Thanks.
