bpratt
I've recently discovered an issue with my f16 where ports have stopped working.
Initially I plugged in a connector on port 10, with it slightly offset, with the data pin of the connector going to to v+, and the ground on the connector going in to the socket third one in.
Finding that port not working I then started plugging that cable in to the next few ports, with the prop not lighting up.
So today I went down with my test pixel, and plugged it in to all of those ports, with it not lighting up, then I tried another port and it then worked. So then I plugged in the same prop, and it didn't work, so unplugged it, then tried out my test pixel in to that port, and the pixel did not light up.
Checked out all the fuses, and all the led's are lit up indicating that it hasn't blown a fuse.
I've also noticed that the little led display is not working anymore too. the OLED was in power save mode that I didn't realise at the time.
