F16V3 Powering Question
Adsy
Sheidow Park SA
My understanding of the manual is that power connections for the Falcon must be either 5 or 12 volts which makes sense.
I will be running mainly 12 v pixels but also have 5v props as well so should i be powering the 5v directly to the props?
Also i have a couple of receivers on order from Daryl , can these be powered by either voltage?
darylc
404 darylc not found
You could always run one side 5v, one side 12v if you are careful not to get them confused (eg ports 1-8 a different voltage to ports 9-16). You can run the receivers at either.
Adsy
Sheidow Park SA
You beauty now i can hook up the matrix i made with the 5v strips i got off you :thumbsup:
Next stop the MEGA TREE !!
