DeeJai
Is that Magic Smoke?!?
ɟɐsʇǝppʎ said:One thing i did have happen with the 2811 strip is that each section is actually part of a bigger section and these sections are soldered together. I had the solder join pull apart, but that was more my doing (well my son really) by applying to much force on the strip and stretching to hard.
Matt the section that needs to be held with pressure is easy fixes, just do a small cut long ways in the strip tube for that sexrion so the cover can be peeled baxk then just run a soldering iron across the chip and componenets and this should resolder any damaged solder joints.
But if we compare the failure rate to our old traditional incands or LEDs then the rate is still way low.
my initial (whilst display is going) fix for the pressure was some electrical tape wrapped fairly firmly around strip at that location.
The tape has also been left on the so i can fix it when my work area is finally setup.
But I like the fix idea. saves me cutting complete and resoldering the entire pieces.
cheers
