Falcon F16V3 - shutting down
orchidman33
I was wondering if any has had this issue with their Falcon F16V3
I was outside lastnight doing a bit of filming, when All the lights went out.
On inspection, I found that although everything was powered up, the F16 had shut down as if it had had it's power turned off.
The only way I could get it alive again, was to turn the power off and then power on again.
Hi, had similar a couple of times yesterday, after a short period of on; my F16v3 OLED screen went blank, although the controller operated normally. I checked for an ethernet failure but nothing it did this a couple of times.
Today I was chasing another problem not controller related, and had to reboot the controller, ie hold down the "sel" button next to the OLED and turn power the controller off and on. Since I did this the OLED screen has operated with no problems. Careful with this as you may have to redifine your IP addrfess.
