Falcon V4 HELP!?!
rossg10
Good Evening/Morning! I got the fully assembled falcon v4 a few months ago. I can connect to my network via Ethernet no problem. I can run test patterns no problem. I can get xlights to control it while networked no problem. I can switch the controller to player mode to use the SD card, I can upload and manually select the sequence and play it.
Last night I tested it all before mounting it outside. I put the controller in player mode, set the time, unplugged the network and power. Plugged power back in. Sequence ran on time, and ended on time. Perfect!! I tried to set up wifi and got NOTHING. The web interface is set up for WiFi, the OLED on controller shows no IP.
Now today.... Mounted and plugged in outside, i can run the test patterns directly from controller. I plugged it into the network and I can run test patterns from the web interface. I set the time, upload the sequence and set the scehdule from the web interface and unplug the network. The allotted time comes and nothing happens. I check the controller OLED and now i have an IP address for WiFi?!?!?!?!?!?!?
SO,
-why did it work last night and not today?!?
-whats going on with the WiFi. Ethernet IP is 192.168.1.242. The WiFi showed 192.168.4.128. I have a fios router with 1 SSID and I have a Eero extender attached to that with a different SSID.
-Why does the time reset to UTC every time I plug into network?
-When I was connected via Ethernet outside and had xlights controling things, colors did not match up at all
-and do i REALLY need to plug into the network to update the SD card?
Any help, pointers is appreciated!
Greg
EDIT: ok. As I work the problem, the different ip’s are because of the eero and Fios. Fios is 192.168.1.xxx. Eero is 192.168.4.xxx. I couldn’t access the web interface no matter what router I was on or what router I had the controller connect to.
Also, I think that even though I can’t access the web when it’s grabbing the IP it’s also resetting the time, just like when I connect to Ethernet. If that’s the case then it explains why the show isn’t starting.
