firmware update P12R with pickit3
robertt
berghem
Today I tried to program a P12R with a Pickit3 and a Y-cable from ed.
I have programmed the unit with:
http://www.j1sys.com/assets/p12r-2.0a.zip
In MPLab I get:
PICkit 3 detected
Connecting to PICkit 3...
Firmware Suite Version...... 01.28.90
Firmware type......................PIC32MX
PICkit 3 Connected.
Target Detected
Device ID Revision = 04300053
Erasing...
Erase device complete
Programming...
Programming/Verify complete
***** end mplab*****
But then nothing on the P12R....
Led 4 stays on; Power is available.
but leds 1/2/3 jump very slowly from 1 to 2 to 3 to 1 etc....
There is no USB or ETH connection possible...
Anybody any idea what I dit wrong or what the problem could be?
Kind regards,
Robert
Still no luck :(
tried to go back to 1.1h still the same behaviour...
Greetings, Robert
Thanks David,
Already done that but I think Ed is bussy, no response yet :D
Greetings, Robert
a couple of day's ago ed contacted me and showed me that I uploaded the wrong hex file to the P12r.
For anyone interested I've modified the sheet sheet from Jeff Rae to be used with the P12r
original post for the PIXAD8 is here:
http://auschristmaslighting.com/forums/index.php/topic,2811.msg25790.html#msg25790
download New Bootloader file:
http://www.j1sys.com/assets/UBL_1.2/UBL_ECG_P12R_1.2a.hex
download the app Firmware 2.7 file:
http://www.j1sys.com/assets/APP_2.7/ECG_P12R.X.v2.7.hex
or
download the app firmware 2.9a from the forum:
http://auschristmaslighting.com/forums/index.php/topic,4972.msg43519.html#msg43519
Download the new PC app Uploader file:
http://www.joshua1systems.com/assets/PIC32UBL/PIC32UBL.zip
Open MPLAB (V 8.92 or newer)
connect your PICKIT 3 to your PC
With power off on your P12r connect Pickit3 to ICSP connector on P12r Making sure that pin 1 (white Triangle) goes to pin 1 on board (White triangle with P1) You can also connect your Ethernet cable to the P12r
Power up the P12r
MPLAB Menu -> File -> Import ... Open the UBL_ECG_P12R_1.2a.hex Previously downloaded
MPLAB Menu -> Configure -> Select Device...
Select PIC32MX795F512L from device drop-down
MPLAB Menu -> Programmer -> Select Programmer -> 6 PICkit3
You should get a message with
Target Detected
You are now ready to erase your PIC32
MPLAB Menu -> Programmer -> Erase Flash Device
Erasing...
MPLAB Menu -> Programmer -> Program
Programming...
Connect your network cable if it is not already connected
Unzip the PIC32UBL.zip and open the PIC32UBL.exe
When it open you will see the window
Note YOUR ipAddress will have reset back to 10.10.10.10
Ensure that that you have Ethernet section Enabled
Click the "Connect" button if you have not removed the power from P12r it should respond immediately
You should get message saying that you are connected
You should now have an enabled "LOAD HEX File" Button Click this and load your ECG_P12R.X.v2.7/9.hex file
You should see a message hex file loaded successful.
Click button "Erase-Program-Verify"
Flash Erased
Programming completed
Verification successful
Your P12r is fully programmed Turn off power for the P12r and Remove PICkit3
Reconnect power to your P12r and use your browser to configure your P12r.
Greetings, Robert
