FIXED: Test pattern not working on universes 4-6, 9 11 & 12
Imacericg
I am hooking the same 2811 strip up to all 12 universes with the test pattern running, and the pattern doesn't work on 4-6, 9 11 & 12 universes, but works fine on the remaining universes.
As you can see, the settings are identical for each universe:
http://farm9.staticflickr.com/8530/8623815504_103e69f980_z.jpg
And this is how the test pattern looks after a restart. You can see it blinks, instead of changing color:
Rgb
Help!
Re: Test pattern not working on universes 4-6, 9 11 & 12
Can you post a screen shot of the effects page on for the P12?
Should look like this.........
It was an LOR issue. I found out when I unplugged the controller from the computer, the test pattern worked fine.
I didn't have all of the universes setup in Network Preferences, so the Comm Listener was interfering with the universes 4-6, 9 11 & 12.
Yes that would do it.
When the P12R is in test mode it can still recieve E1.31 data and this can cause issues with the way the output appears. Its best to disconnect the network cable when using the P12R test mode,
