FPP 6.3 configuration warning
orchidman33
I got Fpp version 6.3 working last night, but have a warning that I am unable to get rid of.
I have Fpp loaded onto Pi3+sending a signal to a Falcon F16V3. Communication is not an issue and I am able to run a sequence from Xlights and also the Fpp.
This is the warning that i have
Any help would be greatfully recieved.
Under the output or eeprom settings it looks like you may have a BBB cape selected. If running standalone as a master then you should be able to delete the virtual eeprom and/or delete the cape in the output settings.
Thank you for the suggestion of deleting the cap and eeprom.
I found the settings and even though they showed RPI2-8d+, I made it non active and deleted the eeprom. The warning dispaired so I reinstalled the eeprom again. All working fine. 👏
  • Like
Reactions: AAH
