Fuses and fire
Discussion in 'Power Supplies' started by Boof63, Nov 20, 2014.
  1. Boof63
    Boof63 Senior Elf Generous Elf
    Nov 7, 2011
    583
    31
    Kadina
    Can some one please show actual photos of fuse types used and where they have been placed,
    I understand sizes will vary depending on draw etc.
    reason for this I had my first smoke turn to fire in a module tonite, a little scary. :-[ :-[ :-[ :-[
    1. Fuse types and locations please.
    2 if using two different psu (opposite ends of house - how do I wire up please so I don't cook anything)
    3 if getting power to pix4 and matrix on roof , do I
    a. run 12 volt from psu on ground upto roof and pix 4 & matrix
    b. run 240 volt to pix4 and psu x2 on roof (metal roof)- so its close to matrix
    Cheers and thanks
    Boof63
  2. viennaxmas
    viennaxmas New Elf
    Sep 6, 2012
    38
    0
    In the top right corner you can see an automotive fuse holder with ATC fuses for the low voltage side.
    For next year I am considering adding fuses on the high voltage side as well. At the moment I rely on the panel breaker / GFCI for that but I wanted to at least have something on the low voltage side...
  3. viennaxmas
    viennaxmas New Elf
    Sep 6, 2012
    38
    0
    For the question where to place the Power supply: as close as possible to the pix matrix otherwise you will either need super sized cables or you will lose to much voltage
  4. OP
    OP
    Boof63
    Nov 7, 2011
    583
    31
    Kadina
    Thanks for the photo, I have fuses only for 12 volt to power injection, thanks for tip and product Viennaxmas. as for roof power, understand would need large cable to run from ground level , but is doing that safer than running 240v/10map extension cord across the roof. (could I use same extension cord for 12 volt run -cut off plugs etc?)
    cheers and thanks again
    Boof63
  5. AussieDoug
    AussieDoug Full Time Elf
    Dec 1, 2012
    375
    0
    Try use a lead long enough so it can run from the roof to an internal power point for the 240v. You want as little distance as possible between 12v supplies & the lights so voltage drop doesn't become an issue.
    Here's another pic. This is 1 meter from my mini trees.
    [​IMG]
  6. Habbosrus
    Habbosrus Back again
    Dec 5, 2012
    757
    17
    Swansea, NSW
    Wow. There is no way I am posting pics of my setup :-[ . Those are very neat/professional looking.
  7. damo1271
    damo1271 Full Time Elf
    Oct 12, 2011
    197
    5
    Adelaide
    Same here! My setup looks like spaghetti...
  8. gerry
    gerry Senior Elf
    Dec 19, 2012
    805
    5
    Surrey Hills,Melbourne
    Exactly my thoughts.
    Despite 'cleaning' my setup it still looks like a bit like a teenagers bedroom (no offence meant) compared to the picture posted :)
  9. OP
    OP
    Boof63
    Nov 7, 2011
    583
    31
    Kadina
    thanks for the pix , really put me to shame fellas, LOL,
    always aspire to better , thanks Boof63
  10. damona
    damona Full Time Elf
    Oct 23, 2013
    282
    7
  11. J
    J New Elf
    Jan 4, 2011
    22
    0
    north of brisbane
    If i was worried about running 240V on the roof i would supply it with 24 or 36v and use dc-dc voltage converters to drop it down at the modules/controllers.
  12. viennaxmas
    viennaxmas New Elf
    Sep 6, 2012
    38
    0
    @damona - yes, I ordered them in an auto parts shop - about half the price of Amazon...
