BillyTRichVa
- Jul 19, 2012
Thanks for that Eddy. On my 2801 pixels, the IN side is the side with the chip.
BillyTRichVa said:Thanks for that Eddy. On my 2801 pixels, the IN side is the side with the chip.
The answer is to use a combination of observations, many times the pixel has some markings on the board, if you use a maginfying glass, then through the clouded cover of the pixel you should hopefully see some markings telling you which wire is which.BrianJ said:I am going to answer one question and post another. I will differ the answer to any more experienced member that can correct or verify what I say.
You can splice in wire for the runs across your windows and not waste any pixels. You should be able to splice in enough wire to go around the window(s) if you like to keep the windows clear.If the run was to long the pixels you placed in for regenerating the signal would not be "null pixels" as labelled by the controller but would be pixels that would be included in your channel count and you would have to sequence around. Null pixels are set by the controller and used at the start of a run to gain the required distance from the controller to the first lit pixel in the run. Controllers do not have the ability to set null pixels in the middle of a run.
There has been a lot of discussion in this thread about ensuring that you maintain the correct wiring order when attaching and changing pixels to stings. (dc polarity, clock, grnd, in and out side of pixel) How do you verify this on a pixel or string? Is it all a trial and error thing, a visual thing or something that can be measured with a multi-meter?
Thanks, B
I would believe you could do this in LSP in 2 ways. When you create a matrix you can then go in and edit that matrix channel arrangements so you could then assign the channels manually, a bit of a time consuming thing but one way to try and do it as a matrix.dpavisic said:Really good stuff guys and I really appreciate you sharing your knowledge.
I'm designing how I would use some pixels for my display (don't use any at the moment but got all enthused after going to the Sydney mini) and was thinking about putting them across the front of my house. I have attached a picture of what I am thinking.
The yellow would be the pixels that light up and the orange ones would not light up. My understanding is that I could make the orange ones Null (?) but it occurs to me that this would be a waste of these pixels. Am I right in saying that I could simply run some wire from the end of the yellow string across the front of the window to the start of the next pixel which is at the end of the window (only around 2.0m) and this would be fine. If the signal did not get across all the way, then I could simply introduce 1 null pixel to regenerate the signal?
Assuming I did not need a null pixel (as per my picture) my concern with this approach is that if I ran a transition across the front wall, is there any way that I can use LSP to make it realise that Pixel 7 around the windows does not line up with Pixel 7 for the strings under the window? If I could not then the transition would be out of alignment due to the "gap" in the windows?
Does this make sense?
