- Thread starter
- #1
As some are already aware been playing with the a bit and have got it to a point it may be useful.
Attached in the ZIP you will find two vbscript files, they have some internal documentation so people can see what they do.
Also a sample pixelmap.csv is include. This is based on my own proposed mapping for the megatree.
Requirements:
This has been tested with the latest version of ImageMagick, the portable version.
Getting started:
Choose a location with plenty of space, though with todays HDD's this shouldn't matter.
ImageMagick download page
http://www.imagemagick.org/download/www/binary-releases.html#windows
Once you have down all that you need some image files to actually process.
There are many options but for the Windows world VirtualDub is what i am using.
http://www.virtualdub.org/
Sorry can't run through a how to use but the goal is to open a mpg file and then export as Image Sequence into the imageinput folder above.
Once you have a set of images in the folder, it's time then to get your hands dirty at the command line.
Open a CMD window and change to the drive and folder you created in the beginning.
Here is my full command line with all options
cscript imageprocess.vbs /inputfolder:imageinput /width:40 /height:56 /imagetype
ng /nogif:false
Check the images folders and see if it worked
if so, you can now run the ppmprocess.vbs file
here's my command line
cscript ppmprocess.vbs /outputfile:mymatrix.vir /mapfile
ixelmap.csv
The pixelmap file was generated in excel and exported as a comma separated list, if no pixel map file is provided a 1:1 mapping is done.
Here's the headers from both script files
'Script ppmprocess.vbs Version 1.1
'Purpose: Convert a selection of PPM files into a Vixen Routine file
' Primary use for RGB Matrix sequencing.
'Author: Aussiephil from forums.auschristmaslighting.com
'Requirements:
' Script must be located in a parent folder to the PPM files, the ppm folder must be called outputppm.
' output folder vixenvir MUST exist.
'Copywrite: Aussiephil 2010... with credit to mrpackethead for the original perl scripting (that made little sense to me)
'Aurguments accepted by script
' /outputfile:<name of file>
' /mapfile:<name of file>
'Version 1.0: Released 16 Oct 2010
'Version 1.1: Released 18 Oct 2010
'Script imageprocess.vbs Version 1.1
'Purpose: Convert a selection of image files into PPM files that can be processed
'Requirements:
' Script must be located in a parent folder to the image files, the image folder defaults to imageinput.
' Output folders are created if they are missing
' The ImageMagick convert.exe MUST be located in a subfolder called IM6
' /inputfolder:<name of folder> no trailing slash and defaults to imageinput
' /width:<pixel width of matrix>
' /height:<pixel height of matrix>
' /imagetype:<file extension of images> defaults to png
' /nogif:<true/false> only true required, defaults to false and outputs gif files to assist.
Phil
UPDATED File
Version 1.2
Pixel Map now used correctly.
NOTE: after saving your csv file please open in notepad and remove the QUOTE marks around the text data especially the RGB entry.
The default output file is a pastelog file open this file select all, copy to clipboard and then just paste in Vixen.
NOTE: For larger matrix sizes this file can get quit large and have examples over a 100Mb. I would seriously recommend installing Notepad++ it's free and handles large files quite well.
Another file is created that contains a Channel Order for vixen, this can be pasted into a sequence file or a profile file, i would suggest the profile be used.
Requirements:
Getting started:
- Create a folder and name it something sensible to you, mine is called TigerVMS (Tiger Vixen Matrix Scripts)
- Unzip the attached scripts into this this folder
- Create a subfolder called IM6, download the portable version of imagemagick and unzip into this folder.
- Create the vixenvir folder, this is not yet auto-created if missing
- Create the imageinput folder, this is the default location for image sequences.
'Requirements:
'Requirements:
Phil
UPDATED File
Version 1.2
