GS8208 Nodes Color Issues
BenF
Hello all
I have purchased GS8208 nodes from Ray Wu for my Mega Tree (only 3 meters tall so not that Mega) which I have been struggling to get right colors from the nodes. For example white was blueish. I have played with the Gamma Curves in Xlights to get the colors to look close for a static color but it becomes noticeable that it is not correct once I place a image on it. Does anyone else have experience with these nodes and if so have the correct settings for Xlights Gamma Curves?
You probably just need to reduce the blue level a bit under Dimming Curves > RGB Brightness/Gamma. It's possible that the colour temperature of the led is more cool white rather than warm white.
BenF
Yes have tried that and found that it is more than adjusting blue down I have had to adjust brightness on Red up as well as adjust the Gamma curves to get close but still not 100% and was crossing fingers that someone here may have settings that works as a starting point. I have managed to get close on single colors but it becomes noticeable with a image not showing the colors right
