HE123-4T HE123-RX Long range pixels
I've now got the HE123-RX back in stock. What it does is connect to the HE123-TX or HE123-4T and gives the option to extend 4 WS2811 pixel outputs by up to 100m. The HE123-4T connects to a pixel controller, pixel tester/s or connects part of the way through a pixel run. The connection is via either a RJ45 connector on Cat5/Cat6 cable or to optional 5mm terminals. The differential signal from the HE123-4T is sent via a standard Cat5/Cat6 patch cable to the HE123-RX which has 4 fused outputs. Both boards can be ran from 5V or 12V.
http://www.hansonelectronics.com.au/product/he123-4T/ (4 channel differential transmitter)
http://www.hansonelectronics.com.au/product/he123-rx/ (4 channel differential receiver)
http://www.hansonelectronics.com.au/wp-content/uploads/2017/07/HE123-User-Manual-V1.0.pdf
