Yendor
- Sep 27, 2022
A properly crimped insulated lug will be strong than an uninsulated one, because they "double grip" the cable - there's a crimp onto the insulation that acts as a strain relief for the metal-on-metal crimp. But you'll need a proper crimper to use them - the dirt-cheap ones from car shops won't work reliably, and pliers definitely wont work. One like this will:@DarkwinXThe bit of extra copper showing on the blue does not concern me too much. For the ground connection, I typically slide a bit of heat shrink over the crimp part of a terminal. One can use insulated terminals but I've never had much success with not severely damaging the insulation sleeve when crimping the terminal.
https://www.altronics.com.au/p/t1552a-crimptool-ratchet-automotive/
