goodyearkl
- Jul 18, 2023
Anyone have the holiday coro skeleton band (dancing, drummer, guitar)? If so would you mind sharing a sequence? I haven't a clue how to get them to do anything. Thanks in advance!
AC for thoseOh boy. Are you putting pixels in there or A/C lights?
Making sure I understand what you mean when you say "how to get them to do anything".
Are you using xLights or something else? Is the prop in the layout, connected to the controller, working, and you just need to sequence it?
If not yet, have you seen this page with the models? https://www.holidaycoro.com/kb_results.asp?ID=185
In my travels, I have seen only one sequence that uses these props... Monster Mash.
View: https://vimeo.com/227355103
It has ON and OFF effects applied, but it ought to be easy enough to put state effects on also.
I haveIt may match, but then again it looks like there is a model mismatch too. For example, "body" under "skeleton drummer" probably matches "drummer body". But the xlights model has "arms up" and the LMS seems to have more control over each arm separately. So, you may want to adjust the xlights model you got a bit and wire it with more strings so that you have enough segments to use the LMS file.
For curiosity, what controllers are you getting and how many plugs are on there?
Thanks. I think the problem is I don't know how to adjust the model.It may match, but then again it looks like there is a model mismatch too. For example, "body" under "skeleton drummer" probably matches "drummer body". But the xlights model has "arms up" and the LMS seems to have more control over each arm separately. So, you may want to adjust the xlights model you got a bit and wire it with more strings so that you have enough segments to use the LMS file.
Thanks yeah its the 16 so I'll try to get one running and if it works I'll get another controller.Probably a bit off topic, but which controller has the long range ports for the A/C controller to attach to? I can't quite make out what is in the two darker boxes on the left, maybe that's it.
Anyway looks like 16 A/C ports there, so 5 or 6 controllable segments per skeleton. This may not be enough to do each arm and leg separately.
