Light Delight
- Sep 30, 2025
Hi everyone,
We are working on a project using the Falcon F16V4 controller and have run into a problem. Our goal is to:
Questions:
Any guidance or recommendations you can provide would be very helpful.
Many thanks,
Ihor Ivasiv
- Record sequences in xLights (exported as FSEQ files to SD card).
- Play these FSEQ sequences locally on the Falcon using the Player/Playlist feature.
- Trigger these recorded sequences via an Anytronics AnyScene 512 Scene Recall Unit (installation manual attached).
Questions:
- Is there a way to use DMX input from the AnyScene controller to trigger FSEQ files stored on the Falcon?
- Do I need to use two Falcon controllers (one as DMX-in, the other as Player) to achieve this?
- Or is there another recommended method to achieve triggering FSEQ files using the AnyScene recall unit?
Many thanks,
Ihor Ivasiv
