ThanksYes you can
thanks for the reply, my concerns were that the max power supply to V1 and V2 shouldn't be more than 350W.Remember to properly fuse the (as shown in your graphic) the 20 Meter power injection runs from the supply to the last string. Strings from/through the controller will be protected by the controller fuses, those not through the controller will need to have fuses added.
Also remember that the pixel string wires will not handle much over 5 Amp (if 18 AWG). In other words, one cannot run say 14 AWG for the 20 Meter to keep voltage drop minimized and fuse it at 15 Amp and then expect the string wire to not burn if something goes wrong.
