I would assume that it does, as the big w lights as you know just look like a plug pack transformer, but they're a little bit more than that.30v Meanwell power supplies should do the same, assuming this transformer doesn't have any multi-function controller built in.
need them for these lights.30v Meanwell power supplies should do the same, assuming this transformer doesn't have any multi-function controller built in.
Oh great.I may have some.
Thanks Al, I just need the Transformers as per the pics. They got thrown out. I can no find these Dash & Dot type transformers on any site I thought I might be someone out there that has some of them.If you've got a lot of those 30V lights and you're wanting to control/synchronise them them a 31V 200W power supply and a DMX18 or DMX2-18 could be on the cards for you. The brick style power supplies will generally have up to about +/- 10% adjustment on them so they could be adjusted to spot on 30V if desired.
