HinksPix Pro Board Blank LED Screen
Lassic
I have a Hinkspix Pro board that shows nothing on the LED screen on power up. I have power cycled numerous times, I have tested voltage on the board and at power supplies and all seems to be good. I have also replaced the power supplies to eliminate that as my issue. Has anyone ever run into this issue with these controllers before and if so do you know of a fix?
Thanks!
Which part number is on the board? Do the status leds do anything? When was the last time it was working and what changed since then? Is there an SD card in it?
PN #925
No LEDs on the board light up except the blue power LED.
When I hit the reset button a green and orange LED light up then turn off. No other lights come on.
No SD Card
925, 2 years old at least... worked last year? Was it R2R or did you get a bare board?
So normally, in addition to the display coming on, the green light will heartbeat:
Also the orange and green at the bottom, will they show network link and activity?
Inspect for visual clues something is wrong, try emergency FW... but there isn't much to fix on these. Ask HolidayCoro, their support is pretty good. In a true emergency, I think I have a 929 (newer but will drop in) in a spare drawer here somewhere.
