HLS with ghosting
Discussion in 'HLS (Hinkle's Lighting Sequencer)' started by Madko, Mar 20, 2013.
  1. Madko
    Madko Full Time Elf
    Dec 24, 2012
    247
    0
    Castle Hill NSW
    Hello All,
    Im using HLS software for programming. Im getting this problem where i have deleted a sequence and saved it but when preforming a test im still seeing the deleted sequence within my test. I think this is called ghosting from what i have read.
    I do get a warning to say 'output to be REBUILT to reduce ghost'. My question is, I'm unsure what it means or how to do it?
    Any help would be great. Thanks!
  2. jhinkle
    jhinkle New Elf
    Feb 22, 2012
    23
    0
    Key West, Florida
    Deleting effects can take time many were complaining about.
    I delayed removal the low-level removal areas so as to spped up the editing process --- but there must give and take in life - no difference in HLS.
    When you want to perform "OutPut" or "Preview" --- I ask you you wish to perform any low-level removals that must take place --- I ask because if just did it 5 minutes ago and have not deleted any effects - then say NO.
    If you elect to bypass my low-level delete cleanup --- Preview or Output will display those effects you deleted but not totally removed.
    Hope that helps explain why.
    Joe
