daunce
Hi all.
I'm moving to attaching more lights higher up on the house (damn you growing hedges!), but I'm not that good within xLights.
I'm trying to draw a model for my windows. These are actually 3 separate windows. The included window frame model doesn't seem to support dividing it, but also only has options to start the string in corners. The only reason I chose to start where I did was to simplify the wiring.
I want to be able to sequence each window frame individually or as a whole.
I was able to use the PolyLine tool, and put in 0 pixels for the second last segment, which I thought was perfect, but when drawing the horizontal segments, holding [Shift] doesn't make it snap to be exactly horizontal/vertical. In the image below, the joins in green are exaggerated. They will be right up against each other to look as if it's a continuous line.
Q1) Is it possible to have PolyLine snap to horizontal/vertical axis?
Q2) Is it possible to use the 'align' option on PolyLine segments?
Q3) Is there a better way to do this? ie: just create a custom model?
I'm still going through xLights tutorials, so feel free to link to specific videos you think may have an answer.
Thanks.
Thanks.
