talk2coxie
Hi Guys,
Thought I'd show you how I ended up using the large plastic enclosures last year. Being a pretty large size I managed to squeeze quite a bit into them.
1 x 12 Volt PSU,
1 x AVD APC731 6 Way Fused Power Breakout PCB,
1 x ECG-PIXAD8,
4 x 27 Channel Controllers (from Ray Wu)
2 x 12 Volt PC cooling fan (from ebay)
I started off by cutting some old particle board cupboard shelving in the bottom to be able to secure the items to. I mounted the PSU and all 27 Channel Controllers to some aluminium angle strip then screwed them to the particle board base. The PIXAD8 was mounted direct to the particle board.
I also cut the holes is the side for the cable glands and made up a sheet metal bracket to hold the cooling fans.
Other photo's of the internals
Internal Photo 1
Internal Photo 2
Cut a rectangular hole in the lid and pop riveted an air vent to help with temprature control
External Air Vent Photo
External Air Vent Close Up Photo
Also mounted some cheap brackets from Bunnings to mount off the ground to the frame I slapped together from old timber decking laying around
Frame Photo
Mount Photo 1
Mount Photo 2
Everything went well for the entire season and I'll be glad to fit out some more enclousres for this year elements and I hope this post is of some help to someone![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
![IMAG0010.jpg](https://dl.dropbox.com/u/43251051/IMAG0010.jpg)
1 x 12 Volt PSU,
1 x ECG-PIXAD8,
![IMAG0011.jpg](https://dl.dropbox.com/u/43251051/IMAG0011.jpg)
Internal Photo 1
Internal Photo 2
Frame Photo
Mount Photo 1
Mount Photo 2
