How to draw a 5 point star in LSP
cscool36
Belrose NSW
Hi All,
I have 12 x 5 point stars which I need to draw in LSP.
Each point has its own RGB channels, a total of 5 RGB channels (15) per star.
Is there a way to draw one and then copy for the other 11 stars?.
Colin
arw01
Eastern Washington
You can copy the controller, but I don't think that will work for the controller channel image. And those drawing tools are lousy is an understatement for coming in and editing it later. I've never had luck with moving elements consistently.
It's painful, but the time spent drawing only has to be done once unless you move the element in the yard. I heard the drawing of elements was part of the rewrite too to increase the tools available in there, and I sure hope better editing of what is drawn.
logandc99
The way I have drawn my main star on my mega tree was doing vertical lines using the rope light tool for each point as I had three modules per point. My 5 pointed stars on my mini trees which have one module per point ( 15 channels each star) was again using the rope light tool but just drawing a single vertical line for each star. Using the shapes provided just doesn't work well
