Srmorgan
- Jan 26, 2020
I am planning on adding the mesmerizer spinner from boscoyo for this years show. But the problem I am running into is that it has 1117 pixels and the falcon f16v3 can only do 1024 pixels per port. I’m planning on running it from a smart differential receiver with two ports. Do I have to make a custom model to set up the two ports that run the prop? I downloaded the one from boscoyo but it is set up with only one string. I changed it to two but I didn’t see an obvious way to set where port two takes over. Any suggestions?
