Re Power injection for the windows.... the strips effectively form a circle... just have power going to the start of the strip and the end of the strip which will be at the same physical point on the window
AussiePhil said:Re Power injection for the windows.... the strips effectively form a circle... just have power going to the start of the strip and the end of the strip which will be at the same physical point on the window
i13 said:You are correct about the number of cores.
As far as I know those are not AWG sizes. The description of the cable I linked to says it is thicker than their 4 core cables. I thought the 24 part referred to the number of smaller strands within the cores. The 020 is the size of each strand.
The 101 manual is here
http://auschristmaslighting.com/forums/index.php/topic,1889.0.html
i13 said:I did not know that you live in the USA. I skimmed through your posts and couldn't see anything about that so I just said what I use.
It would be slightly better to connect the negative to both ends of the circle too. Doubling the positive will help reduce voltage drop but remember that it can occur in the negative line as well. Bench testing with the lead-in cable is a good idea. The data should only be connected to one end if the circle.
Your address might be an issue when trying to get a PixelBone too (ask smartalec). It wouldn't surprise me if there's something similar in the US though because Falcon Player (which is American) supports it. The guys at falconchristmas.com might know and many of them are ACL members too.
i13 said:It shouldn't really make a difference whether you double the positive or the negative instead. It is better than not doubling anything but not as good as doubling both. Even if you have just one negative wire, it is slightly better to branch the single wire to both ends of the strip so the current doesn't have to travel the entire length of the strip to get to an end that's not connected to the negative input. The set number of cores is the reason that I just buy the splittable figure-8 cable and run the wires together with cable ties.
Bench testing will confirm whether there's a voltage issue and voltage drop won't damage anything. I don't have the experience testing the limits of voltage drop for 5V lights first-hand. One thing that will have a big impact on the voltage drop is the distance the power needs to travel in the cable.
Hopefully someone with better 5V experience will post here. There are ways around the problem such as DC-DC converters with different voltage supplies if you want them too far away from the power supply using just cables.
i13 said:Good point AAH; I didn't consider that. I apologise for the slight error in what I said. Doubling the negative is better than doubling the positive but still not as good as doubling both. It would be the single positive wire that you'd branch and connect to both ends of the strip.
AAH is 10% the voltage drop at the start or the far end of the strip?
AussiePhil said:Voltage drop and the 10% discussion.
Some real world voltage readings that throw the 10% number well and truly in question.
Baseline numbers
PSU 350w 5V nominal
PSU no load Vout : 5.55V
PSU load Vout: 5.54V
Cable from PSU to String input:
5M 32x020 10A figure8 cable
Pixel String 100 count 2811 nodes, single ended power feed for testing
Vin to string, No Load: 5.54
Vin to string, full white: 4.5V
current draw @ 2.6A at PSU
String starts to get pink ting around pixel 60.
2811 IC
Vin (min) 3.3v (-+0.7v)
Vin (max) 6v to 7v
Currently unmeasured
Voltage at middle of string
Voltage at end of string
