I must be missing something in backing up my XML files
jspaulding22
Marysville, OH 43040
I am probably missing something here. I created a Matrix on my home PC. I copied the MyUserMatrices.xml file to my Dropbox account so I could load it on my work PC and finish the matrix. I put the xml file in my LSP setting folder but it does not show in my Macros/Marquees menu on the left like it did at home. What am I missing?
Thank,
Joe
arw01
Eastern Washington
I am pretty sure that's userpatterns.xml over there. I've not dropped a matrix over there, I don't tend to leave a lot in that spot as I clean it out when I am done using them.
Since LSP doesn't store the gradients and such WITH the macros, swapping machines means moving that file around as well and this starts to be a pia if you are actively using a couple of machines to keep them in sync.
kenlmcse
Lightshowpro Developer
Gilbertsville, PA
Most of the files you need are in the My LightShow Settings folder
But I forgot to add a couple files to this folder so you have to go to program files\Minleon\sequencer to copy these
UserGradients.grdx - this is all the color slider gradients you created
tbmru - this is simply all the files you have opened
