Seancrv
Greetings all,
I ran into a snag while setting up my strips for window outlines. I had been running five temporary arches, three meters/90 pixels each. They were hooked to outputs one through five on an F16v3 controller using xLights and worked great thanks to some help on this board. After a few weeks, I unhooked them and started installing permanent pixel strips around doors, windows, etc.
I started with a clean slate in xLights and sent a new sequence for each addition of lights to test things. I was able to get the first two windows working, the first garage door working, but ran into a problem on the second door. The last 31 pixels do not light, it is like they do not exist. Everything looks to be correct in xLights and program numbering.
Each window/door is hooked to its own F16 output. The windows have 226 pixels and garage doors have 195 pixels. The garage doors are entered into xLights as a three sided Poly-Line. There is so much information that could possibly be off that I decided to wait for requests rather than posting 20 different configuration shots.
I’m not desperate yet but I am getting there! Thanks in advance for any help.
Sean
Sean
