Is there anywhere to get LOR boards serviced/repaired in Australia?
scotthorwell
Engadine
i've now used all my spare channels and at the end of the season will need triacs and other components tested and replaced. Is my only option to send to USA?
I did try and change a triac, but I'll keep my soldering skills to joining to bits of wire together......
Benslights
Elderslie
is it just a triac that needs changing??? as I may be able to help you with that otherwise David is the best
scotthorwell
Engadine
Thanks @ryanschristmaslights and @Benschristmaslights .
I'm not sure if its only a Triac, but channels are on as soon as power is connected and stay on during show. I sourced the Triacs, but couldn't be sure that's the only issue. When the season is over I'll test the three units I have fully and then send you a PM Yagoona Lights to see if you think its just the Triac.
I've moved to RGB this year, but still have props that are 240v that I'm not ready to part with yet so if I can get them all fixed up and slowly over the following years move everything over to 12v (or other)
Thanks again and Merry Christmas!
