j1UBL2??
Robert
Wisconsin
I got my new toys from Ed today. I got the ECG-DP2 and a P12D. I cant for the life of me find the j1UBL2 file for connecting my PC to the DP2. I checked my pc, thinking maybe it installed when I hooked up the DP2 to the PC through the USB Port. but it didn't self install. I've read through the DP2 Quick PDF, it mentions the new boot loader but doesn't have a link. Am I going crazy, or is it looking me in the eye???
Robert
Wisconsin
there is hope :D. The link says, The folder '/Public/j1sys/nECG-DP2/j1UBL2' does not exist. I do appreciate your effort though.
Bill Ellick
NY
I sent you a message on the update bootloader.
Also for all here are a couple of shots of the upper board to help with setup.
This shows the K1 jumper set for 5VDC input along with two of the selections for outputs.
The chip on left J12 is set for differential output and the chip on the right J9 is set for single ended output.
This shows K1 set for 12/24 VDC input
This is the "greenie" connector showing the output connections for hooking up the pixel leads depending on which type of 3 or 4 wire pixels you will be using.
