Knock knock, it's September... October... November! What are you making and are you ready for Christmas 2026?
Gave the hedge a light trim, this should allow more visibility into the yard.
One more bush to do on the south side of the front fence once the green bin is emptied again.
This year new
column matrix x2
Efl candy canes x5
Efl showstopper wreath
Efl show stopper snowflake
Efl singing girl.
New B8 controller
Redesign controller rack
Redesign push for music
Final week of October check-in, how is everyone's progress?
I have completed a control box build, painted some coro, pushed pixels into said coro, and started putting up some of the lights outside (starting with the more discreet elements). I meant to grab some photos of the painted coro props but forgot before it got dark. I'll try to post a picture or two one evening next week.
My new props consist of a reindeer, three 2D presents, and a couple of star poles. With 350 bullet pixels boy is the reindeer heavy! O_O
checkin for last week of october - pushed pixels into inkcreations props, bit hard as the material is more solid, so very sore hands, even with pliers, - had to wrap the handles of the pliers in strapping tape to help as the handles are soo tiny
down to my last 1000 pixels to push into other props
got all my controllers out of storage and have updated all to new 10.3 - they perform so much better now
and the new features showed me one prop was causing an entire controller to act slow and drop frames, - so split that prop to 2 ports per prop and now the controller indicates it can now keep up with the sequence speed and all other controllers ( such a cool feature letting you know a contoller is not able to keep up )
now to finish building my 180 degree poles, using 8 inch seed pixel toppers and 3m tall poles
so looking good for start next week to start installs ready for December 1st
also 3d printing some mounts for props standard coro prop to 25mm hole for poles
but need to find one mount that is 4 holes around a single pixel - for a star
other than that looks like im actually on course for once (touch wood)
How about everyone else ?
First Year have some props that have been populated and more need populating and many hours of x lights learning to do and no motivation to do it and another controller box to build
Here's the reindeer and two of the three presents (not final location). I decided to leave the antlers white to make them stand out against a dark brown fence at night. For this same reason I also opted for a lighter brown/orange for the fur.
Hopefully the paint holds up in the weather but I did finish it with Rust-Oleum 2x Ultra Clear. Undecided if I'll leave the bolt heads black or stick of a bit of paint on them too.
that actually looks cute
im glad im not the only on thats finding coloured props are nicer for during the day, did you paint that one yourself ?
(better that plain white or black - but i cheat now and get impression props )
@Juddge : Yes I did paint it myself. Used normal acrylic paint with a brush though, only the top coat was sprayed on.
I have some printed gingerbread people and star poles from Ink Creations, plus Boscoyo Mini Trees on green coro so thought a white reindeer would look odd. Particularly for the first part of the show where it is still twilight until as late as 9pm (daylight savings).
Well, I finally got off my butt and started getting some things done this weekend!
Last year I built two of these matrix boards to go on my solar panels, but never got around to finishing the remaining four. So that's what I started tackling on Saturday.
All the seeds have now been strung, and power has been wired up on two of the four boards.
Still to do: Connect the data between the strands.
Now for the engineering masterpiece...
After carefully building, assembling and GLUING the whole lot together, I discovered I'd installed every single strand backwards. Turns out the whole Data In vs Data Out thing is actually quite important. Who knew? Apparently not me. 🤦‍♂️ At least they are consistently bad across the panels.
So these four will start in the top-right corner, while the original two start in the top-left. Because apparently having everything consistent would have made life far too easy.
Hopefully I can work around it with some adjustments in xLights. Otherwise, they'll get flipped and you'll be looking at the backs of the seeds instead. A completely unintended feature, but a feature nonetheless!
At least I've used different coloured xConnects (white vs black), so it'll be easy enough to tell which boards are which.
Here is what they look like when lit up - I like the diffusion the clear polycarbonate panel gives to them
This year I’m considering ripping out the controller of some landscaping lights and putting in my own, I am also considering broadcasting FM because my speaker broke and a transmitter is cheaper. I have been procrastinating for the last few months so I am not ready
i cannot recommend enough using FM transmitters and a QR code onsite to either Pulsemesh or Tune2 - (pulesmesh is my preferred) - FM for parents that dont want to get out of the cars with little kids, but for people walking by, the pulsemesh is the best, and it shows how many people have watched your show via the app
Another weekend down, what did you achieve this time?
I have installed two new star poles from Ink Creations, each squeezed in between existing air seed tube leaping arches.
Also repaired a faulty section of Ray's icicles - as one of the only WS2811 elements, when a pixel dies here it is much more obvious without the data backup redundancy to keep the downstream pixels still working. The question for 2027 is whether to order new icicle strings with data backup or take the opportunity to switch out the icicles for a more even gutter matrix (more density between drops, but reduced height).
And existing mini trees and about half of my mini arches are now up, too.
