Knock knock, it's September! What are you making and are you ready for Christmas 2026?
Zero motivation to buy or build anything new this year, so it will likely be copy/paste of the previous year (which was also a copy/paste of the year prior)
I am in a very similar boat. I don't think there will be any changes, unless if I end up finishing the solar panel matrixes I started rebuilding last year.
Maybe I'll take down the 3 singing bulbs that are still on the roof :)
im making 180 degree poles using the SFL 8 inch topper for top and bottom - using string lights with 32 strands x 8 poles
and ive added extra mini trees and 5 stars to make it look like a shooting star above my 180 degree poles
Bit skint this Christmas prop making season so I've just ordered some amazon special pixels (1000 for $175), can't be any worse than 2022 right? xD . I've rebuilt an old Surfing Santa rope prop using seed pixels for $80, and using a Hanson piHat for control via Xlights. I'm doing a nightclass welding course at TAFE and made some waves for under the surfboard and chopped the whole thing into two sections to make storage easier. It came out quite well. It was my sons favorite at a neighbours house so hope he loves it.
Also using my Brisbane mini seed pixels that I won in the raffle to create the wire frame train that I grabbed off Bazmick. thanks mate!
I created PETG clips for both and printed and used them to hold the seed pixel wire flat on the frame so get the correct orientation of the pixel. Will post up progress on them and how I did it later if anyone is interested. I used Booy's Aussiepixelstore to create the xmodels for those.
Also created 3 EFL Penguins, which are so cute, and using the skills I learnt from the Brisbane mini to use states for the singing props. :)
Making progress. I still get funning comments from people that I'm working on my lights in August! o_O
@Dreamin if the amazon pixels are good and work well let me know and send the link as i need some cheap ones so might order some myself
Ordered 31st Aug and they just cleared customs in Brisbane. 500 for $99 + got a discount for buying two lots and free postage. My inner Scotsman was overjoyed.
I’m sure they will work ok but long term not sure, but at least I can get what I want done this year.
80mm between each - so 3" spacing, not the standard 4". You might be hard pressed to get them into props.
They arrived today. 130mm between pixels but it looks like a 4 year old made them. 😂. Excess material all over the place and they are short so might be a pain on the bum to push into this Coro. Do they work, yes. Are they great definitely no. Were they cheap, yes. 😂. Glad I didn’t order more but hopefully they will work this year and be replaced shortly after for something quality.
I've been working on a bunch of spiral pixel stakes.
14 5v seed pixels each.
24 of these in total. in a 8 wide by 3 depth layout. I'll place them between my arches and mega tree.
The spiral stakes came from The Warehouse in 1.5m lengths. I cut these in half.
I did keep some full height ones for another location in a garden.
My list:
  1. "Push to listen" capability to save having to put a speaker in and out each night
  2. Replace remaining Advatek controllers with Falcons to unify hardware support
  3. Migration from E131 to DDP
  4. Wall mounting controllers for easier access
  5. Show integration with permanant mounted leds (they have dedicated PiHat controllers)
  6. Replace weatherproof indoor matrix with a new build using outdoor panels for improved reliability and quality (indoor panels have warped)
  7. Clean up cable runs and lengths to improve fault finding and reduce clutter/trip hazards
  8. Label all connectors to improve fault finding
  9. Update sequences to optimise use of sub models where applicable (e.g. ShowStopper)
Hi everyone. For the past 8 years, I have been running a few Arduinos on a display across a couple of larger trees in the front yard. Decided to update this year and wanted to continue with something a little different than Falcon or ESP, so I settled on a Pico. Started programming in June, but since I am not really a programmer it took a couple of months. I have the hardware prototype working with 45 programs, wifi to my phone and a touch screen on what will be the controller. Have just started this morning laying out a bench test from the schematic to confirm other pieces like the MAX485s work. Hoping to have 3 channels at 600 pixels each and pushing the signal about 30 metres. It's taking forever to figure it out and still need to send off for a pcb board once it is done. Fingers crossed it's ready for Christmas.
Here is the prototype
Made it as far as the switching this morning on the full bench test.
pushed 2000 pixels over the last couple of nights - my fingers hurt only 4000 more to go lol
