Landscape lighting transformers
Superman
Ipswich-QLD
all the gear we use is low voltage DC not AC.
so I dont think that is a very good option for you
sfleck
Ontario
thanks Superman
i wasn't planning on purchasing and using them for any new install, i was thinking about using what i already have installed (which would be a great location) and using them to inject power to the DC seasonal stuff
You can use a rectifier to change the voltage from an AC to DC voltage, but the DC volts will still not be completely clean.
The best way is to use a switch mode power supply which will give you clean DC volts and have overload protection as well.
