Laser cutter for 10mm coro
Marius
I would like to create my own coro props. Is anyone using home laser cutters for this? I'm specifically looking for something that can cut 10mm white and black coro. I would love to get some recommendations and see close up photos of what you created and how cleanly you were able to cut 10mm coro.
I have done some 5mm coro props (normally double layer them after cutting) using 100w CO2 laser at work - it does work but the settings have a very small range that works well eg not catching on fire and also not remelting together. Router is the way to go really
I've heard PVC corflute is a not recommended to laser cut.
Due to fire combustion risk, and it producing chlorine smoke/gas. Causing corrosion to your machine.
Common polypropylene corflute melts very easily and is combustible.
