macmanluke
- Oct 31, 2024
New to RGB pixel christmas lights this year but fairly competent with electronics / rgb pixels in other use cases
Just finished building 2x Spiral Trees with starts on top
70 pixel tree - Raywu seed pixels 4 wire 50mm spacing 12v WS2818
joined to (soldered + heatshrink)
50 pixel star - Raywu seed pixels 4 wire100mm spacing 12v WS2818
controlled with a baldrick board
xconnect connectors
All finished tonight and testing it (had tested the components as i built it and didnt notice the issue then)
Have an issue where the last pixel in the star is "slow" changing colour a fraction of a second after the rest
Happens with 1 tree or 2
had 11v at the end of the string with no power injection with both trees
Tried power injection both ends of the strings - both 1 or 2 trees.
Same from xlights, test mode on baldrick, test mode in FPP
Possibly started after i ran the output wire from the top of the tree to the bottom (about 1.2m of 4 core alarm cable)
Didnt notice it before but i also didnt look at it that hard, maybe interferance?
Is there anything like a end of line resistor or something needed?
Dont think its a wiring issue or bad pixel as both behave exaclty the same
Any suggestions welcome
another thing i noticed is the 100mm spaced pixels seem to go full white if they lose data (but not super easy to replicate) - didnt think that was a WS2818 thing?
xconnect connectors
