LawrenceDriveLights
- Jan 16, 2018
I had seen a few people use tomato planters with strip simply wrapped around it and that seemed like a nice easy solution to create a spiral tree.
However I wanted to use bullet pixel nodes as I had them and I also wanted to try and ensure all the lights in the spiral tree would be visible.
I was after something to mount the bullet nodes to that I could wrap around the tomato frames to look like spiral trees. I had some left over building strap (similar to this https://www.bunnings.com.au/abey-25-x-0-6mm-x-30m-punched-metal-strapping_p1090030)
It allowed me to use the punched holes in the strap to cable tie the bullet nodes to then I wrapped the strap around the trees. It did take a bit of time to cable tie the bullet nodes and a lot of cable ties but it did give the effect I was looking for as you can see all the pixels (360 viewing so to speak) as the galvanized strap also gives some nice reflections from the pixels.
Attaching bullet nodes to strap
View: https://www.dropbox.com/s/3fj68p5wlk4q7af/Photo%2027-1-18%2C%2010%2031%2049%20am.jpg?dl=0
View: https://www.dropbox.com/s/uaq0cvl79qgx8mw/Photo%2022-7-18%2C%204%2017%2021%20pm.jpg?dl=0
Looks like this
View: https://www.dropbox.com/s/122bphso47au8pw/Photo%2011-4-18%2C%201%2019%2050%20pm.jpg?dl=0
Basic Spec of Spiral Trees
Approx. 1400mm high
75 bullet nodes @ approx. 75mm centres.
4 x Spiral Trees for display.
Note: Originally was not going to have a Ray Wu type star on the top of each tree.
View: https://www.dropbox.com/s/eq2e0w7rh3w5a5u/Photo%2011-4-18%2C%201%2011%2023%20pm.jpg?dl=0
But they looks a bit small, so went with the Boscoyo coro ones instead
The Ray Wu stars get used later.
I will add a video of them in the next few days
Looks like this
Approx. 1400mm high
