Hi,
I am in the process of going over to Xlights 4 from LOR.
The process has been very time consuming, I have created 606 individual models.
Then have mapped each one through the mapping tool. I did not want to do it through the Data layer, as I want to be able to edit the LOR channels.
Now I want to convert my LOR Sequences.
Is there a quicker way to import the LOR, as the only way I can load the mapping, is to create a music sequence, select the MP3, then in the sequencer TAB, right click on new timing to select edit display elements, then add them, I have to select the 606 models, then I can add the mapping, I had created earlier.
As you can image, having to do this for every sequence
appreciate any suggestions.
Deblen
Deblen
