Mega Tree Null Pixels
spaulgal
Hi our mega tree needs 8 starting null pixels for most strings, but some strings need 29. I see how to set null pixels for the mega tree globally, but can I adjust some per string?
You can't set it per string in xLights. Visualiser doesn't support mid-prop null pixels. You'll need to manually configure it on the controller as per Dan's suggestion, once you've done your upload. Note that every time you re-upload from xLights, you will lose that configuration.
why not setup as it isand control the prop via a sub model that does not use those pixels ?
thats how i woul;d first try to get around this issue
Thanks gents. I did update the nulls on the controller side.
