DanW
- Jun 8, 2020
Greetings Everybody,
Have long wanted to be apart of this exciting community! Started ordering stuff a couple of years ago and have never got the Mega Tree rocking! More than ever I would like to distribute smiles via the Mega-Tree - this year - I know, may already be too late for this Christmas . It may be safe to say that I need a tutor or a few tutors (and my head examined).
Electronics: This is the controller https://sandevices.com/product/e682-assembled-tested/ I guessed that this was the place to start. I would have said assume but you know what that spells. http://sandevices.com/wp-content/uploads/2017/11/E682_Operating_Manual.pdf. So I start reading the manual and page 2 is blah, blah, blah..."up to 170 pixels or 510 channels (3 channels for each pixel)". With the lights on hand = 4,480 leds / 560 pixels.
16 rope lights = 5m DC24V GS8206 IC(similar to WS2811 IC) 56LEDs/m 7pixes/m) WHITE PCB led digital strip;IP65;in frosted silicon tube. https://www.aliexpress.com/item/32827169718.html
Also have a T-1000S LED sd card pixel controller, that the Pixel LED manufacturer said would work https://www.aliexpress.com/item/1202295883.html?spm=a2g0o.detail.1000023.1.466672c6DtYuKL or should I get another controller shipped overnight? Something a little more capable to make up for the problem sitting between the keyboard and chair. Something Falcon?
The ends of the rope lights both being wired 5m apart. Power supply = Mean Well HLG-600H-24A, need an outdoor box going between 120 and 32 @ 24a outputs (16 at top of LED ropes and 16 at the bottom, bottom of rope lights will be about ~5 feet off of the ground - should I daisy chain controllers?). This Mean Well power supply has a 5v data output for the show control board (at least I think it works that way). https://www.meanwell.com/Upload/PDF/HLG-600H/HLG-600H-SPEC.PDF
Average December temperatures around here, Victoria BC Canada, are 8°C/3°C can be as warm as 21°C, with 13 days of rain expected, there is strong wind as well.
And just because it is fun to say 4,480 LEDS (all running to the beat of your favourites), 560 pixels = sourcing scripts suggestions?
Curious for your thoughts
Dan
Dan
